Alternative Fuels , Additives , Fluids Diesel Fuel, Off Road Diesel Fuel , Bio Diesel , Synthetics , Oils , Lubes , Fuel Additives , Emulsifiers , Demulsifiers , All Alternative Fuels , Additives and Fluids
Which Power Steering Fluid?
Old Aug 22, 2008 | 03:35 PM
Marine's Avatar
Default Which Power Steering Fluid?
Since Amsoil isn't releasing their PS fluid by next weekend, I need to figure out what to put in my truck. I flushed it once before and used synthetic, but I can't remember which one I used. I would have to go through my receipts. Whatever it was, it stopped the whine in cold weather.
However, I have a MileMarker Hydraulic winch that I will be installing Sept 1-3, so keep that in mind when you recommend something. For those of you who do not know, the hydraulic winch is powered by the PS pump when the winch is engaged.
Thanks!
Old Aug 22, 2008 | 03:37 PM
wildbill's Avatar
Chrysler recommends ATF+4, which can be found in a fully synthetic formula!!!
Old Aug 22, 2008 | 03:41 PM
Marine's Avatar
Where does it recommend that? Show me where and I will be forever grateful.
Everything I have seen says NOT to use ATF. If I am wrong, I will gladly use Amsoil ATF.
Old Aug 22, 2008 | 03:44 PM
wildbill's Avatar
Look in yer owners manual!!
Old Aug 22, 2008 | 03:50 PM
Marine's Avatar
It says, " Do Not Use Automatic Transmission Fluid."
Go look in yours...
Old Aug 22, 2008 | 03:53 PM
wildbill's Avatar
Ram Diesel Engine Information
Old Aug 22, 2008 | 03:56 PM
Marine's Avatar
94+ Recommended Fluids
* 47RH - Mopar 7126 ATF Plus
* NV 4500 - Mopar 4761526 or Castrol Syntorque SAE 75W-90 GL-5
* NV 241 and 241HD - Dextron II
* Dana 60, 70, 80 - SAE 90 GL-5
* Limited Slip - Chrysler Friction Modifier 4318060
* Brake Fluid - DOT 3 Brake Fluid
* Power Steering - Chrysler Power Steering Fluid
* Chassis Grease - NLGI no. 2 EP chassis grease
* Front Wheel bearing (2WD only) - NLGI no. 2 EP high-temperature wheel bearing grease
* Engine oil - API CF4-SH 15W40
Is this what you are looking at?
Old Aug 22, 2008 | 03:58 PM
wildbill's Avatar
Go look in yours...
The hell, I had an 01 and it said ATF. Same as the 06.
Old Aug 22, 2008 | 04:00 PM
Marine's Avatar
Go look again. My book is for a 2001.
wildbill's Avatar
OK, Royal Purple makes a full synthetic P/S fluid.
