Audio Equipment/Electrical Discussions Based on Automotive Stereo Equipment Such As Amps , Head Units & Speakers Including Installation and System Set Up Information. Electrical or wiring issues on anything that requires wiring.
Diesel Bombers Truck/Car Audio Set Up Tracks Test And Tune
Old Aug 20, 2008 | 10:15 PM
DB Admin's Avatar
Banned
Default Diesel Bombers Truck/Car Audio Set Up Tracks Test And Tune
Features HZ Swing and 2 Second Constants from
13.5 HZ 2 second Constants to 1000HZ
Variable Full range Sweeps
Surround Sound Test Track
SPL Bass Test
All Equalization,Gains,Fade,Balance,Bass,Treble Should be Set to 0 , Volume 100% then Adjust Mediums to remove Any Distortions , Once all Tones are Clean and distortion Free at 100% Volume then the System is Set up Correctly , If you do not hear some of the tones your system has Dead Spots , Look for Speakers that include the HZ readings your missing and upgrade , Note The Higher and Lower Ends of the HZ are not Audible to the Human Ear
"The full range of human hearing extends from 20 to 20,000 hertz."
If you have Distortion you can connect In-line crossovers
exp. 100 Hz low-pass
Will Allow 100HZ and Lower HZ to pass to speaker , Find the Speakers Range and Connect an inline Cross over to adjust the HZ to its range
If you have a Full Range of Speakers and still cannot pick up the HZ you should be and you have the amps HZ set correctly and still have distortion Then you should look at picking up an External Equalizer
May Damage Speakers , Amps Or Ears , Use Caution
http://www.dieselbookmarks.com/bombers/Diesel Bombers Professional Audio Set Up CD.zip
Old Aug 25, 2008 | 09:49 PM
2001shrtbedcummins's Avatar
Dang dm, If ya got em blow em huh?
Old Aug 25, 2008 | 09:50 PM
DB Admin's Avatar
Banned
collateral damage
Old Aug 25, 2008 | 09:54 PM
DieselHardware's Avatar
Sweet, I can definitely use this, especially with the explanation as to how to use it properly. Now I just need to get a cap and bigger amp so my sub doesn't keep drawin the amp down and killin it when the bass is up to high.
Old Sep 10, 2008 | 08:47 AM
ETXBlueRam's Avatar
Like this?
Old Sep 10, 2008 | 09:31 AM
stkdram55's Avatar
SUMBITCH does that suck
Old Sep 10, 2008 | 04:46 PM
I need to burn this to a cd and take it into work and blow all our subs.
Old Sep 10, 2008 | 07:16 PM
Red_Rattler's Avatar
High Tech Redneck
Be SURE to have a vid cam when you decide to do this!!!
Old Sep 10, 2008 | 10:10 PM
MotorOilMcCall's Avatar
I used one of these CD's to wreck our speaker panel at Sears when we got out of car audio... All the guys from hardware and appliances came over at the end of the day, we put in the CD and cranked it up with all the subs, speakers, and amps on... My manager grabbed 2 fire extinguishers just in case. We blew out every sub, and both the Sony amps started smoking, .
Old Oct 2, 2008 | 03:37 AM
97cummins's Avatar
