Oil Pressure Drops 98 12V
Old Jul 21, 2008 | 05:25 PM
supersportjim's Avatar
Default Oil Pressure Drops 98 12V
i was coming back from taco bell 3 mins away from my house and just driving down a back street doing 25 mph at most oil pressure drops to 0 and comes back up. did it again a min later. what would cause this? thanks
Old Jul 21, 2008 | 05:49 PM
kbailey's Avatar
crap in the sending unit maybe?
Old Jul 21, 2008 | 06:27 PM
i will give it a shot tomorrow. thanks
anyone else?
Old Jul 22, 2008 | 02:05 AM
Jim this is a common problem - my 98 12V has been doing this for awhile now. Usually, the sender just craps out and you have to replace it. I installed a mechanical oil pressure guage in the cab because I was worried and hadnt replaced the sender yet. My oil pressure ranges from 30 psi to around 90 psi (winter months with 15W40 oil):
https://www.dieselbombers.com/12-val...-pressure.html
Anyway, if you have oil in the crankcase, there is a VERY good chance that the problem is the sender. The Cummins p/n should be: 3923200. And the sender can be seen here (OIL PRESSURE SENSOR):
Durtyd09
Nov 11, 2015 01:43 PM
purnell82
Jul 22, 2015 10:42 AM
jhprice
Mar 29, 2015 09:36 PM
powerstroke4178
Nov 27, 2014 02:35 PM
Jeremy Babb
Chevy/GMC Duramax 01-04 LB7
13
Oct 1, 2014 06:27 AM
