Cummins X15 Engine — Fault Analysis
Old Apr 8, 2026 | 01:22 AM
steven shi's Avatar
Default Cummins X15 Engine — Fault Analysis
Cummins X15 engine was disassembled due to abnormally low oil pressure; upon inspection, significant issues with its internal structure were discovered. We now present these findings to you.
1,The camshaft of the Cummins X15 engine exhibits signs of fracture and cracking, as well as evident material spalling.
cummins x15 engine crankshaft
2. The teeth of the idler gear on the Cummins X15 engine exhibit distinct signs of friction.
cummins x15 gear
cummins x15 gear
3.Both the main bearings and connecting rod bearings of the Cummins X15 engine have been rendered unusable due to abnormal friction, exhibiting deformation or internal scoring.
Cummins x15 engine main bearing
cummins x15 engine beariing
Low engine oil pressure is a very serious issue that must be taken seriously. If this problem arises while driving, you should stop immediately to inspect the vehicle in order to minimize potential damage.
If you have any further questions regarding engines, you are welcome to join the discussion. I have a maintenance and service guide for the Cummins X15 engine; feel free to take a look if you need it.
Old May 11, 2026 | 07:09 AM
isaiasflores's Avatar
Banned
ytu6uu7
Marjaq
Diesel Engine Conversions
May 11, 2022 02:38 PM
PistonPat
For Sale
Jan 10, 2016 11:03 PM
Newly Retired
Mar 20, 2013 08:59 AM
RSWORDS
Dodge Diesel Tech Articles
9
Sep 13, 2009 11:50 AM
RSWORDS
Mar 28, 2009 03:05 PM
