Turbo actuator
Old Jan 12, 2026 | 01:28 PM
Sealman's Avatar
Default Turbo actuator
Can someone tell me the wiring order for the turbo actuator on a 2018 Ram. I need to know what wires are the power, ground and Can wires. I’m trying to diagnose a trouble code of U010C.
Old Mar 30, 2026 | 10:16 PM
azepewifug's Avatar
Banned
Diagnosing a turbo actuator issue can be tricky, especially with a code like U010C, which typically indicates a communication problem with the actuator. For the wiring order on a 2018 Ram's turbo actuator, you generally have four wires: power, ground, and two CAN bus wires for communication.
Old Apr 1, 2026 | 12:15 AM
azepewifug's Avatar
Banned
Originally Posted by azepewifug
Diagnosing a turbo actuator issue can be tricky, especially with a code like U010C, which typically indicates a communication problem with the actuator. iring order on a 2018 Ram's turbo actuator, you generally have four wires: power, ground, and two CAN bus wires for communication.
To troubleshoot, start by checking the wiring for any signs of damage or corrosion, as this can disrupt communication. It’s also a good idea to test the power and ground connections to ensure they’re functioning correctly. If everything appears in order, you might need to look into the actuator itself or the vehicle’s control module for further issues. Proper diagnostics can save you time and effort, so take it step by step!
dirtyoffroad
6.7 Liter Dodge Cummins 2013+
Mar 20, 2020 06:58 AM
greenbomb
Chevy/GMC Duramax 04.5-05 LLY
13
Mar 8, 2010 07:51 PM
Benjamin
Diesel Auto Power
17
Dec 2, 2009 10:38 PM
nightmoves
Sep 6, 2009 10:04 PM
kennyb
04.5-05 LLY Performance
21
Sep 24, 2008 08:26 PM
