Intake air temp sensor plug
Old Sep 22, 2024 | 07:53 PM
six speed's Avatar
Default Intake air temp sensor plug
I recently picked up a 08 sterling bullet 45 with the 6.7 Cummins. The lady’s husband had died and she was wanting to sell it. He had been a diesel mechanic in the navy and had done all the work himself. I’ll start off with a list of parts on the truck and then tell you what I’m looking for. The truck has efi live with the csp5 switch, A valair quiet dual disc, dps add a turbo s475 kit, afe boost tubes, gdp grid heater delete plate with inline grid heater and intake horn, fuel system with 1/2” line to the pump, new injector pump( maybe stock size, maybe bigger?). I had both turbos rebuilt and had the vgt turbo upgraded to a 64mm wheel and high flow exhaust turbine.
I still didn’t think the truck was running as good as it should. And it was throwing a code for the turbo speed sensor. Got that changed. Hooked a bully dog gt up to it,after ordering an edge cts3 to find out they have no support for sterling trucks, and found the map sensor was bad as well. Got that changed and this truck has really come to life. The intake air temp sensor reads 0* on the bully dog. I found in the delete plate that the man had installed a plug. I’ve got a sensor ordered. I would like a picture if possible of where the harness is where the plug comes out of and what the plug looks like. I ordered the sensor like the one in my 2012 and I know what that plug looks like, but can’t find one like that on this truck. He tucked all the wiring harnesses behind the fuel system block and I’ve dug around there but haven’t found the plug I think it should be.
Sparks2010
07.5-12 Cummins 6.7L Tech Talk
Sep 27, 2017 11:35 AM
skav
Jan 26, 2012 11:00 AM
powerstroker13
May 3, 2011 01:10 PM
oldcobia
Chevy/GMC Duramax 01-04 LB7
8
Nov 9, 2008 09:12 PM
wildbill
Jul 15, 2008 09:18 AM
