‘16 Chevy duramax 3500 high country coolant level low
Old Apr 28, 2024 | 01:13 PM
Mkessler1's Avatar
Default ‘16 Chevy duramax 3500 high country coolant level low
I have a ‘16 Chevy duramax 3500 high country with 180,000 miles says coolant level low I replace a small amount then does it again I replaced the cap and the tank and doesn’t help it is holding antifreeze in both sides of tank and always has pressure. I have had it deleted and changed out cp4 truck runs good has not changed in temp while driving and ac not blowing hot then cold
Old Sep 12, 2024 | 11:52 AM
JohnC12's Avatar
It sounds like you’ve already tackled some key areas. Since the coolant pressure is holding and temps are stable, have you checked for any small leaks in the hoses or radiator? Also, a head gasket issue could cause coolant loss without obvious signs like overheating. Might be worth getting a pressure test done just to rule that out.
Old Sep 12, 2024 | 11:54 AM
Mkessler1's Avatar
yes it was heads
bluesfan
Sep 12, 2013 11:47 PM
RWalters
Aug 14, 2011 11:16 PM
Diesel_Daddy6.0
Jan 31, 2011 08:43 AM
vlado
Mar 31, 2010 09:55 AM
mrtwiss
Jan 20, 2010 10:51 AM
