06 lbz no start
Old Jan 23, 2024 | 11:57 PM
dwhj1995's Avatar
Default 06 lbz no start
I was driving my truck 06 lbz and it started to run bad I stopped and it went back to normal so figured it was just a hiccup started to drive agin went about a mile and a half and started to run bad agin then died got a code for crank position sensor came up replaced sensor and still no change I tried about 3 other sensors and tested the last one I put in to make sure it worked checked fuel pressure that was good checked compression had about 300psi on all cylinders pulled the glow plugs and had fuel misting so I believe injectors are good I pulled the crank position sensor out and put my finger in and the gear feels tight and scoped it and it looked good I even pulled a known good ecm out of another truck and that ended up good everything I’ve tested turned out to be good I ran out of things to check so I’m hoping someone has some in site to help out all help will be greatly appreciate
dwhj1995
Jan 23, 2024 11:48 PM
Aaron Carlton
Chevy/GMC Duramax 06-07 LBZ
Feb 9, 2020 10:45 PM
Jeff.Hopper
9
Aug 27, 2014 06:47 PM
WyattsRam
Feb 27, 2013 05:26 PM
solerunner
11
May 15, 2012 05:42 PM
