Diesel Bombers Sponsors These Great Manufactures, Distributors and Vendors Support Our Forum
Cylinder leak down results have me confused
Old Aug 24, 2023 | 09:42 PM
Pstrokin's Avatar
Default Cylinder leak down results have me confused
Hello I have a 1999 Ford power stroke. 280K miles. Cylinder #1 failed CCT , shows 380 psi dry compression 6 crank revs. Other cylinders are 420-440 psi. I ran a leak down test on #1 and got bad numbers 80% leaking. No leakage from valve train. No air from oil dip stick tube ,no air in coolant tank. All the air is leaking in the push rod ports in the heads and seems like most is closest to cylinder #1. Normally this would make me suspect piston ,rings or cylinder issues, however my truck has never smoked , has never shown any signs of blow by "very minimal vapor and a ping pong ball will rest on oil fill cap ". I do not think I can show 380 psi with 80% cylinder air loss and see no signs of blow by from crank case gases ? Do u think it's possible to blow a head gasket without mixing water/oil , without pressurizing cooling system, without blowing coolant out exhaust ? Could the push rod channels in my head be where a blown head gasket is pressurizing ? Are the push rod channels connected in the head ? Anyone have any info or comments concerning the lack of blow by yet air coming from push rod channels? Thanks
mikej
Dec 24, 2012 02:35 PM
corvetteguy
Nov 28, 2012 08:06 AM
Yamwr450
10
Dec 2, 2011 11:48 AM
MotorOilMcCall
15
Jan 10, 2009 08:57 AM
wildbill
Sep 26, 2008 08:53 AM
