Towing and Hauling Diesel Discussions of Towing and Hauling Practices , Techniques , Tips Including Trailers , Campers , 5th Wheels , Goosenecks , Boats and More
Hooking up a Prodigy
Old Apr 17, 2007 | 09:56 PM
CumminStrong's Avatar
Default Hooking up a Prodigy
I will be hooking up a prodigy on my 03 ram. I ordered the harness for my dodge. How do I know if my truck has the attachment needed to hook up my controller? Are there any pics that I can see to see where to hook it up? Thanks!
Jay
Old Apr 17, 2007 | 10:08 PM
Longhorn's Avatar
Dont have pics but there is a flat square plug under the dash around the steering column. I think it is the only plug that dead-ends....and of course will match the harness from Chrysler...Easy to find, plug it in and then splice to the prodigy and you are good to go. If i can take some pics i will!
Old Apr 17, 2007 | 11:15 PM
Hawg Hunter's Avatar
I just installed one in my 03. The plug is flat and light blue in color. Look for it around the e-brake and fuse block. Real simple installation.
Good luck.
Old Apr 17, 2007 | 11:53 PM
Cool! I did see something that dead ended near the e brake but it was white in color with a cap on it. I will try to see if there is one that is blue though. Will be installing this weekend with the goose neck B&W hitch. Any pointers on that would be appreciated too!
Jay
Old Apr 19, 2007 | 08:48 PM
bentwings's Avatar
Mine was tucked way up behind the e-brake even though it had been used before.
The Prodigy was probably the easiest install I've ever done. I just mounted the pocket that came with it on the dash right in front of my right knee. It is at about a 45* angle so it will work going up or down. My son and I share a trailer and the controller so it is easy to just unplug the controller and swap vehicles.
SMatyac
Nov 4, 2014 10:29 PM
