Diesel Bombers Sponsors These Great Manufactures, Distributors and Vendors Support Our Forum
Upgrade your suspension with a Superlift Lift Kit + Rebate
Old Jul 30, 2021 | 05:50 AM
carid's Avatar
FormerVendor
Default Upgrade your suspension with a Superlift Lift Kit + Rebate
https://www.carid.com/superlift/
Superlift is a pioneer in the industry and is one of the few suspension companies operated by true truck and off-road enthusiasts. Offering lift kits for your truck with upgraded component options to brands like Bilstein and KING will give your truck the height and ride quality that you're looking for.
The suspension upgrades available provide a lift height between 2.5-4”. Regardless of which Superlift lift kit you choose, you can rest easy knowing that you will have everything you need to safely increase your truck’s ride height and give it a complete suspension overhaul.
This summer, enjoy a fascinating rebate on Superlift Lift Kits at CARiD! Receive a $100 Truck Hero Prepaid Card with the purchase of Superlift Lift Kit value above $499 through September 30, 2021. Please check the PDF form for a complete list of rules and instructions: https://images.carid.com/superlift/p...ebate-form.pdf
Superlift® - Master™ Lift Kit
https://www.carid.com/superlift/master-lift-kit.html
Fits:
2012-2016 Dodge Ram 1500
2WD and 4WD models
Features:
  • Retains factory ride quality, steering geometry and CV axle angles
  • Front track width not increased
  • Front lift height range
  • Full-width differential / control arm crossmembers provide lateral rigidity
  • Load bearing bracketry made of .25" thick plate steel or DOM tubing
  • Front differential housing does not require trimming
  • Dual centerlink stabilizing links make steering more responsive and extend pitman / idler arm life
  • Lifetime Warranty
carid
Apr 19, 2021 09:32 AM
carid
Feb 3, 2020 07:11 AM
carid
Mar 1, 2018 06:13 AM
W350-4x4
Mar 14, 2015 12:25 PM
jbradley113093
Oct 8, 2009 11:05 PM
