Fuel leak from filter housing
Old Feb 5, 2019 | 04:29 PM
bucketoval's Avatar
Default Fuel leak from filter housing
I have 97 3500 and I have fuel coming out of the center of the fuel filter housing on the bottom this is the second time. last time I change the filter which was about 2 months ago. All the o rings look good. Can the fuel heater cause this?
Old Feb 25, 2019 | 08:56 AM
sonnylynnvick75's Avatar
Is it coming out of the Fuel water seperator?
Old Feb 25, 2019 | 10:29 PM
bucketoval's Avatar
I guess there is open space in the center of the fuel filter canister. Someone told me that is where the water come out. But I not know
Old Feb 26, 2019 | 07:55 AM
On your fuel filter there should be a plastic piece on the bottom with a spring. This piece when pressed in releases the water that has been separated from the fuel. If you don't drain that when ever you fill up water can be in there, freeze, and crack the plastic causing a leak. Your options are to replace the fuel filter with a closed bottom fuel filter ( google search will give you the answer) or you need to buy a new fuel water separator relief valve.
Old Feb 26, 2019 | 02:52 PM
PEKOKITTY's Avatar
On the side of your fuel filter canister there is a lever, it might be yellow in color that you turn to open to drain the water out. Check and see if is closed all the way.
Old Mar 11, 2019 | 05:15 PM
JBearSVT's Avatar
Get rid of it. Gano's sells the spin-on filter retrofit, well worth avoiding the many headaches of that stupid canister design.
dusty6812
Sep 28, 2014 10:40 AM
bulldog99
Sep 26, 2012 07:49 AM
sweetv8s10
11
Oct 30, 2011 01:53 AM
wildbill
For Sale
Feb 26, 2011 08:46 AM
oglejust
Jun 29, 2009 07:11 PM
