98 12v misfiring
Old Nov 5, 2018 | 12:16 PM
Blackbetty98's Avatar
Default 98 12v misfiring
My 98 fires up fine, after driving has a bad miss. I can drain the water separator and it will level out. Once I drive again it's back to the same thing. I've changed the filter, took fuel sample and no water or debris. Recently have put in new 50hp injectors, overflow valve, pre-heater delete. It could be coincidence but it seems like it started this problem after I changed the OFV. Need help on what else the issue might be. Any advice appreciated.
Old Nov 9, 2018 | 09:12 PM
Bigg Redd's Avatar
If you have a temp-gun, you might be able to see if you have a dead cylinder or at least one with low temp. That may indicate a failing/ failed injector issue. What is your fuel pressure?
Old Nov 15, 2018 | 07:26 AM
Thanks for the reply. Turns out the new OFV I got was bad. I decided to put the old one back on to see if that might make any difference and it fixed the problem. Fuel pressure went straight to 20 at idle after putting old one back on. With the bad new one was only getting 10 at idle.
Old Nov 16, 2018 | 09:16 AM
Bigg Redd's Avatar
Wow, good catch! I would have missed that especially with a new OFV. Enjoy........
etdavenport
Oct 27, 2016 12:21 PM
Mitch564
17
Jul 21, 2016 03:10 AM
eddie7644
Jun 10, 2013 08:18 AM
dom1505
Feb 24, 2013 07:13 PM
SFC Diesel
8
Oct 20, 2010 09:47 AM
