2003 5.9 running hot
Old Oct 25, 2018 | 07:49 AM
Jacob Boyd's Avatar
Default 2003 5.9 running hot
Hey guys, I have a 2003 5.9 that is running hotter than it use to. Running down the highway at 70-75 It gets to around 215-220 degrees unloaded. I’ve put a new thermostat, and fan clutch and there is no change in temp. I changed the antifreeze in the past 20,000 miles. The truck is stock and use to run around 200 no matter what. What else am I missing? I’ve checked the coolant and it is not leaking coolant either. Do y’all have any suggestions?
Old Oct 27, 2018 | 01:14 PM
chopforman's Avatar
clean your rads out.you have no air flow.
Old Oct 27, 2018 | 01:20 PM
Jacob Boyd's Avatar
what do do you mean by rads?
Old Oct 27, 2018 | 01:29 PM
chopforman's Avatar
radiator, a/c condenser and tranny cooler
there need to be wash out or air blow threw them
Old Oct 27, 2018 | 08:08 PM
chopforman's Avatar
how did you make out?
Old Oct 27, 2018 | 09:49 PM
Jacob Boyd's Avatar
Man, didn’t get to it today due to work. Should tomorrow or Monday. I’ll let you know. Thanks for the reply
Old Oct 28, 2018 | 08:50 PM
Jacob Boyd's Avatar
Radiator and condenser are clean. Can you think of anything else?
Old Oct 29, 2018 | 07:47 PM
chopforman's Avatar
the other thing you could do is pull your rad and take to a rad shop and get checked out
Old Oct 29, 2018 | 07:49 PM
chopforman's Avatar
or try another thermostat . maybe that one is no good
Old Oct 31, 2018 | 06:44 PM
chopforman's Avatar
I talked to my diesel buddy he said take the rad to rad shop and get a flow test done to it
You have a rad problen
