04.5 cummins cutting out
Old Jul 21, 2018 | 02:01 PM
Dean4502's Avatar
Default 04.5 cummins cutting out
I have an 04.5 cummins that is stock except for a 4” exhaust. It started cutting out really bad. It will cut out for several seconds at a time. There are no codes. I changed the tps sensor, injectors, *the sensor on the back of the injection pump and the fuel rail pressure thing. Just to see what would happen I took the smarty s06 tuner off my other truck and installed a tune on it and the problem went away except it started surging when it gets up to speed. Not bad but you can definitely feel it. I’m at my wits end and am losing my mind trying to figure it out. Any help would be most appreciated.
Old Jul 22, 2018 | 09:04 AM
Bigg Redd's Avatar
Hows your fuel pressure? Im surprised you didn't get any codes. Have you ever cleaned all of the ground connections? A bad ground will also raise havoc.
Old Jul 22, 2018 | 10:15 AM
Dean4502's Avatar
At the pump 17 at an idle and 12 getting on it. At the rail 6,600 idle up to 22,000. I’ve checked all the easy grounds.
Old Jul 22, 2018 | 10:34 AM
Dean4502's Avatar
What I don’t get is what is messed up that doesn’t throw a code and the smarty s06 changes
Old Jul 22, 2018 | 11:02 AM
Bigg Redd's Avatar
Well that answers that question...…..
Now Im starting to think of a possible short circuit somewhere. Something is definitely amiss......
Old Jul 22, 2018 | 12:15 PM
Dean4502's Avatar
It runs perfectly when it’s cold to.
Old Jul 22, 2018 | 01:17 PM
Dean4502's Avatar
After some more trouble shooting I found out it’s turning the shift limiter off on the smarty that is fixing the problem. Any ideas?
Old Jul 22, 2018 | 02:34 PM
Bigg Redd's Avatar
Kripes...ya got me there!!! I'm thoroughly stumped now. Hope someone chimes in with a solution. Send a PM to Dangerous1965, on this site. He's helped me in the past. He's damned close to "Guru" status.
Trev11523
Ford Powerstroke 08-10 6.4L
Jan 18, 2019 11:19 PM
2000Ram2500
For Sale
Apr 11, 2018 08:07 AM
btl4425
Sep 1, 2016 07:05 PM
mysterync
L&N Performance
11
Aug 8, 2009 01:24 PM
DB Admin
For Sale
Apr 17, 2008 11:24 AM
