Hard start problems
Old Apr 5, 2018 | 10:23 PM
Cgreen03.5.9's Avatar
Default Hard start problems
I have a 2003 5.9 with 273k miles I have a air dog lift pump . Edge tuner . 4 inch straight pipe . Even when its warm out it takes a long time to start. I just replaced the prv . When the truck is running it idles fine and has plenty of power. Any ideas ?
Old Apr 22, 2018 | 02:58 PM
Mike Lavite #72's Avatar
Im having same trouble. 2003 5.9 277,475
i started a thread also . not sure if its in the rite place or not
Old May 23, 2018 | 02:29 PM
caleb_secrist's Avatar
Check your injectors. CR have problems due to poor filtration. injectors may be stuck open. I have a truck that did that and he drove it so long it washed number 6 cyl out.
Old May 30, 2018 | 07:40 PM
Bigg Redd's Avatar
How many miles on your injectors? Original injectors?
