‘06 Dodge 265’s to 285’s?
Old Apr 2, 2018 | 12:36 PM
DieselScott's Avatar
Default ‘06 Dodge 265’s to 285’s?
I have an opportunity to buy 4 like new BFG’s 285-70-17’s on 2011 Dodge wheels to replace my 265-70-17’s on 2006 Dodge wheels. Anyone know if these wheels will bolt up and if the larger tires will rub without a lift kit? Thanks for your advise!
Old Apr 2, 2018 | 04:17 PM
chopforeman's Avatar
I have a 2002 ram 1500 and I up sized my tires to that size.
No rubbing and my speedo is dead on now
stock size P265/70/17
New size LT285/7517
Fills in the wheel well and gives it a bolder look
Yes those rims will fit if you got rims too
Old Apr 6, 2018 | 07:30 PM
Thanks for the info chopforeman!
Old Apr 7, 2018 | 07:20 AM
chopforman's Avatar
sorry that new size is LT285/70/17
I made a mistake in my typing
Old Apr 7, 2018 | 07:33 PM
AmericanHotRodSolutions's Avatar
A 265/70/17 is about an inch shorter then the 285/70/17. This should result in your speedometer reading about 3.3% slower with the 285/70/17, not much, just figured I would mention it.
Old Apr 8, 2018 | 07:45 AM
chopforman's Avatar
i GPS my truck with the two different tires
265/70/17 speedo reeds 100km only doing 97km
285/70/17 speedo reads 100km doing a 100km
Old Apr 16, 2018 | 01:23 PM
Bigg Redd's Avatar
You'll be fine.........
