P2503 code (Charging System Voltage Low) in 04
Old Mar 17, 2018 | 06:52 AM
vinnie0104's Avatar
Default P2503 code (Charging System Voltage Low) in 04
Looking to see if any of you have advice or have had this isssue before. My 04 keeps throwing the above code. While driving the battery gauge will bottom out and the check gauges little pops up. I have replaced both batteries, the alternator and have replaced all the battery cables ends with new terminals. All cables and connections are good.
Im don’t know where to go next with the issue. Would it be the PCM? Any advice is appreciated
