Show And Tell Got Photos or Videos of Your Diesel ? - Post Here and Tell Us About it , We Support Most Video Sites , Diesel Videos will Auto Embed .
First Gen Cummins Project
Old Jan 29, 2018 | 09:31 PM
RustyPanda's Avatar
Default First Gen Cummins Project
Hopefully this is in the right section, wanted to share what Ive done to my truck since i got my hands on it .
How i first found it
If anyone knows how to post pictures between lines of text ill do that otherwise i will just attach them on different posts
Attached Thumbnails First Gen Cummins Project-img_20160305_140904745.jpg   First Gen Cummins Project-img_20160305_140923732.jpg   First Gen Cummins Project-img_20160305_140937181.jpg   First Gen Cummins Project-img_20160305_140830922.jpg
Old Jan 29, 2018 | 09:37 PM
RustyPanda's Avatar
Default Bringing it home
Winched it up on the trailer . Tires still held air suprisingly.
Believe it or not I changed engine oil with the truck on the trailer threw a battery in it and drove it off. Started up in less than 10 seconds of cranking after 11 Years !
Attached Thumbnails First Gen Cummins Project-snapchat-4426187551585920591-1-.jpg
Old Jan 29, 2018 | 09:44 PM
RustyPanda's Avatar
Default Cleaning up the cab
Boy was it a mess in the cab. Doors had been leaking for a long time and i could tell the carpet was damp but when i pulled it out it was worse than what i was expecting. Nevertheless I ended up cutting the floor out and patching it up . Cant say Im too pleased with the outcome but it was my first attempt at something like this . I will probably end up redoing it or finding another cab but more on that later
Attached Thumbnails First Gen Cummins Project-img_20160410_174945613.jpg   First Gen Cummins Project-img_20160410_174952860.jpg   First Gen Cummins Project-img_20160410_180013208.jpg   First Gen Cummins Project-img_20160410_185035843.jpg   First Gen Cummins Project-img_20160411_203313668.jpg
First Gen Cummins Project-img_20160411_203328685.jpg   First Gen Cummins Project-img_20160414_170556251.jpg   First Gen Cummins Project-img_20160414_175706282.jpg   First Gen Cummins Project-img_20160414_175731154.jpg   First Gen Cummins Project-img_20160414_175907157.jpg
Old Jan 29, 2018 | 09:49 PM
RustyPanda's Avatar
Default Cab floor mess
Continuing the work on the driver side . It was definitely the worst side of the cab.
Attached Thumbnails First Gen Cummins Project-img_20160430_190029621.jpg   First Gen Cummins Project-img_20160430_190034361.jpg   First Gen Cummins Project-img_20160517_203930065.jpg   First Gen Cummins Project-img_20160517_203939190.jpg   First Gen Cummins Project-img_20160613_182354392.jpg
Old Jan 29, 2018 | 09:55 PM
RustyPanda's Avatar
Default New fender and tires
Front fender was rusted pretty bad on the bottom so i ended up changing it for an aftermarket fender. (questionable fit and quality) Also tested a tire from a friend but really didnt like the style so i kept looking around for something else.
Attached Thumbnails First Gen Cummins Project-img_20160416_181829045.jpg   First Gen Cummins Project-img_20160421_194604355.jpg   First Gen Cummins Project-img_20160427_144405899.jpg   First Gen Cummins Project-img_20160427_145323730.jpg
Old Jan 29, 2018 | 10:04 PM
RustyPanda's Avatar
Default Cleaning up the exterior
Took off the trim as a lot of it was basically falling it off already . The box is actually not the original but it is a factory replacement . the trim by the wheel well had come loose and had filled with mud causing the only actual rust area on it, which was too bad . Like a responsible truck enthusiast I bought some rims and tires before addressing any mechanical issues. Also ended up taking the windshield out as it was cracked and there was water and mildew between the layers of glass.
Attached Thumbnails First Gen Cummins Project-img_20160620_183803734.jpg   First Gen Cummins Project-img_20160620_183820388.jpg
Old Jan 29, 2018 | 10:10 PM
RustyPanda's Avatar
Default Front axle repair
The front u joints were completely shot . Most of the needle bearings had long fallen out and been replaced with mud so i began tearing it all apart . Replaced it with some fresh parts and put it back together for the time being.
Attached Thumbnails First Gen Cummins Project-img_20160622_115814517.jpg   First Gen Cummins Project-img_20160622_115823870.jpg   First Gen Cummins Project-img_20160622_115831775.jpg   First Gen Cummins Project-img_20160628_144902486.jpg   First Gen Cummins Project-img_20160628_144914819.jpg
Old Jan 29, 2018 | 10:18 PM
RustyPanda's Avatar
Default Small things.
For most of the summer I left it like that looked around for small things like side markers and taillights. Tried installing a windshield myself and broke it it . Oops. Also made a stack for the bed and did the free pump mods.Did some cleaning and tried to hunt down some small electrical issues.
Attached Thumbnails First Gen Cummins Project-img_20160819_214322548.jpg   First Gen Cummins Project-img_20160819_214327753.jpg   First Gen Cummins Project-img_20160820_204656602.jpg   First Gen Cummins Project-img_20160820_204704244.jpg   First Gen Cummins Project-img_20160802_175734518.jpg
Old Jan 29, 2018 | 10:26 PM
RustyPanda's Avatar
Default Winter Winter and more Winter
Sat still for most of the 2016-2017 winter. No time or money
Attached Thumbnails First Gen Cummins Project-img_20161225_161227937.jpg   First Gen Cummins Project-img_20170415_162115962.jpg
Old Jan 29, 2018 | 10:28 PM
RustyPanda's Avatar
Default Some cheap turbo upgrades
Tossed a hx35 12cm turbine housing on there during the summer but that was about it.
Attached Thumbnails First Gen Cummins Project-img_20170604_165932641_hdr.jpg   First Gen Cummins Project-img_20170605_224815377.jpg   First Gen Cummins Project-img_20170605_213131557.jpg   First Gen Cummins Project-img_20170607_205238107.jpg
