Inherited 98 turbo diesel thats not running
Old Jan 27, 2018 | 12:43 PM
UssEssexcv9's Avatar
Default Inherited 98 turbo diesel thats not running
Hello All,
My father in law passed away several years ago and his son has finally given up on his old truck. He took it after his dad died as a daily driver and it wasn't long before he started having trouble. Not being an overly motivated guy he did try some things but then gave up and left it in the parking lot at the plant he worked at for 2 years.
My sons talked him into letting them have it and so the project begins. I wasn't excited to get it at first because there wont be any expense the boys wont accept and I know I will be the one expected to pay. I must admit though that its value is more than sentimental and I would like to have access to it's pulling power from time to time.
Heres the scoop;
The truck was produced (as per the door sticker) in 2/1998 making it a 98 model. I see that the forum breaks up trucks into 24 valve 98.5 and newer versus pre 98.5 models which are 12 valve. This one seems to not fit either category
This truck is a 24 valve turbo diesel 5.9 liter Cummings 2500 Dodge Ram
The truck wont start. Paw in law had some cold start issues which we attributed to faulty glow plugs. He would use the block heater even though we rarely get below freezing here in south Louisiana and that seemed to help. He also used starter fluid which I thought was frowned upon for diesels.
He replaced the turbo not long before he passed (it went out) and it probably got about a years worth of daily driving after that.
When it quit on his son, he had someone come to the plant parking lot and replaced the fuel pump. It hasn't run since.
So, the truck turns over without trouble and has a new turbo, fuel pump and filter. I do not assume anything except the turbo was installed correctly.
Questions I have;
How can I check to see that the glow plugs work?
How do I know if the fuel system was primed properly?
Is starting fluid a no no?
What should the fuel pressure be? Brother in law says that they had 10#
Thanks in advance,
Jim
Old Jan 27, 2018 | 04:50 PM
turbo2332's Avatar
Lots of things wrong with your post
first its a cummins
second cummins dont have glow plugs. They have a grid heater
you need to hook it up to a scan tool and see if its throwing vp44 death codes.
if you run a vp dry they die.
fuel pressure should he 15-18 idling
Old Feb 4, 2018 | 10:16 AM
Not sure what it means that theres lots of problems. I did mention i am not a diesel mechanic and that it was a cummings diesel.
thanks for your input on the type of heater it has. I tried to check the codes but there was some connection problem not yet overcome.
One would assume that i could also check the heater with an ohmmeter if i knew where the connector was?
you provided the appropriate fuel pressure range but the truck is not running so checking pressure at idle is not yet possible whcih leads to my next question.
The fuel pump cycles when i turn on the key, is there any diagnostic value to knowing this pressure?
Old Feb 4, 2018 | 11:46 AM
AmericanHotRodSolutions's Avatar
He was saying there is no "G" in Cummins. Its not cold enough to worry about the grid heater. Your truck would be 98.5+. You can crack the line at the VP44 injection pump or even the fuel filter on the drivers side of the engine area to check for fuel. Once you have decided which fuel line before the VP44 to loosen a bit turn the truck on and crank it for a couple seconds and let the key stay on, after a few seconds return the key to off. Do this a couple/few times. If your pump is working you will see fuel leaking. This is a very rudimentary way to check but it should work. Perhaps someone has a better way as well.
Old Feb 4, 2018 | 12:19 PM
Gotcha and thanks for your reply.
Ill try the fuel check you mentioned and report back.
Jim
Old Feb 5, 2018 | 08:47 PM
Hillbilly1's Avatar
Possibly bad fuel too, especially if the fuel was bought after a hurricane! LOL! Sitting two years probably didnt help the fuel quality. If it hits a lick or two with a small shot of ether, it probably is a fuel issue.
Old Mar 1, 2018 | 12:30 PM
Default Update
Thanks for your comments. I went to perform the tasls suggested and found he batteries were poopoo. Bought a new set and installed them the other day.
I drained the fuel out and put in 5 fresh gallons
loosened a fuel line downstream of what appears to be some sort of fuel distributor.
turned the engine over and wintnessed s slow drip. Expected to get a lot more but what do i know
I sprayed some starting fluid in the intake and turned it over
it hit pretty good and was borderline running for a second
knowing absolutely nothing about it, is there a way to prime the fuel lines after replacing the fuel filter?
i know the filter was changed but dont know what was done after to prime it
Jim
Old Mar 1, 2018 | 12:37 PM
I reread the post with fuelncheck instructions
i didnt try 3 times leaving the key on
Ill do that again today and report back
Old Mar 2, 2018 | 02:16 PM
turbo2332's Avatar
any codes? and knock the 17mm banjo bolt loose on the pump to purge air out of the main feed line if that is a concern for you.
Old Mar 11, 2018 | 04:35 PM
I cracked open the banjo fitting on the pump side of the fuel filter and turned on the key. Diesel sprayed out at a good clip so I tightened it up and repeated this with the engine side of the filter with the same result.
downstream of the filter is a device with several lines coming out of it. I loosened one of the lines coming out of it and we turned the key on. Waited for the pump to cycle and then cranked on it a few seconds. Waited a bit with the key still on and then did that twice more. The fuel that came out was a drip, not the flow i had on the filter at all.
we have not had any luck getting codes yet. Looking for someone with a different device to try with. The first one couldnt communicate.
what do yall make of the flow test?
is there another way to test he grid heater?
Jim
