1998.5 ram 3500 diesel loss of power check engine now dead?
Old Nov 21, 2017 | 07:19 PM
mrmarkman's Avatar
Default 1998.5 ram 3500 diesel loss of power check engine now dead?
thanks in advance, driving my 1998.5 dodge ram 3500 5.9 cummings turbo, 1 block from home when a felt a jolt check engine appeared and truck drove at idle, drove to driveway backed up and parked, could not make pedal make any more throttle, stuck on idle, turned off, will not turn back on. has 11 codes, some duplicate, all start with the letter P, 1389,1683,1693,0237,0251,0216,1688,0237,0251,0216, 1688. how can I start, b ought a fuel filter, will buy new batteries, was told could be that and they are 5 years old each, but any more info will help.
Old Nov 21, 2017 | 08:27 PM
caleb_secrist's Avatar
From what I understand the "1688" and the "251" the dead pedal with no TPS codes sounds like the VP44 took a crap on you. what id do is crack the injector lines at the head and see if you cant get some fuel to come out. if not remove rubber line off injection pump before it enters and see if the lift pump is supplying fuel. Id do this before I rule a VP cause they aren't that cheap.
Old Nov 22, 2017 | 12:56 PM
Blair@BD's Avatar
FormerVendor
Low voltage will cause multiple issue so you want to check the voltage on your batteries while cranking to see if they drop below 10 volts. If the batteries are good you need to make sure there is fuel pressure at the VP44 from the transfer pump. if that's good you can hook power and ground to the pump using bullet connectors (pins 6 & 7 but can't remember which is which, make sure you have it right) and if it starts and runs it's not the pump if it doesn't then it is the pump. We sell one with a pressure alarm light to let you know when your transfer pump fails so you can fix it before your injection pump is damaged.
https://www.dieselperformance.com/sh...ed-alarm-16482
