Trans swap help
Old Nov 17, 2017 | 06:49 PM
Glsawyer.drig's Avatar
Default Trans swap help
Motor is a 89 7.3
i need to mount a 6spd from an 05 5.4 to it.
i have trans and motor. Also complete new clutch and flywheel for the 7.3
Old Nov 22, 2017 | 03:24 PM
Anybody?
Old Nov 23, 2017 | 05:30 PM
u2slow's Avatar
Guys have significant trouble using the diesel ZF6 behind the IDI.
https://www.oilburners.net/threads/z...-as-zf5.52923/
Not even sure where to begin with the gas version.
Personally, I very much liked the ZF5 when I drove IDI's. I plan to use one with a 6BT some day. Just shift the tcase to low range when you want a creeper gear.
Old Nov 23, 2017 | 06:51 PM
Only issue is my truck is a stock zf6. And i use a pto with it
Old Nov 23, 2017 | 07:11 PM
I read about redrilling a 7.3 idi flywheel to fit a ps 7.3 pressure plate and disk. Thats fine. Just need to know for sure.
According to southbend clutches the zf6 used with my stock motor....5.r triton... Is the same input shaft as a zf5 used with the idi
Old Nov 24, 2017 | 07:09 PM
If not possible to us my stock zf6.....what about changing the main case?
Old Nov 24, 2017 | 10:56 PM
u2slow's Avatar
I'll have to suggest you ask the guys over at oilburners. They know it better than I do.
