Installing new chip into my 24 valve
Old Nov 2, 2017 | 02:13 AM
Bits16's Avatar
Default Installing new chip into my 24 valve
So I drove my truck into the shop everything was working perfectly fine. Started to pull things apart and installed my new edge juice with an attitude and once I was done it all I fired it up and it' s but it no longer has any throttle response and is throwing three codes P0237 P0122 P1693 if anyone knows something should be greatly appreciated
I also have not hooked up my fuel pressure sensor to my fass fuel system. But I'm 90 percent sure that is not my problem ​​
Old Nov 7, 2017 | 04:49 PM
2000Ram2500's Avatar
Po237 means map sensor voltage to low and that code has popped on me only when messing with the map connecter such as installing a chip. P1693 just means that there is a code in the companion module. I’m not exactly sure what p122 is I think something with the pump. Google it and it should tell you
Old Dec 29, 2017 | 01:47 AM
diesel life's Avatar
P0122 is a accelerator position sensor voltage too low i believe
