dana 50 ring&pinion swap
Old Oct 6, 2017 | 05:11 PM
Ned'ers's Avatar
Default dana 50 ring&pinion swap
Greetings everyone, i need to swap ring and pinion out of my axle, from my research i need to remove driver side wheel. spindle and axle. Then the drive shaft and then axle cover or member. Remove the right side axle to get the carrier out. replace the gear set plus shim correctly, then repeat in reverse.
If anyone has expeirence with this please chime in.
