lost power
Old Aug 28, 2017 | 05:14 PM
rollincoal88's Avatar
Default lost power
no pulling power up hills with 3H trailer loaded
no take off power sputters until you let off pedal
no passing power
lose speed going up hill
notice rpm is close to 500 i had it up 900
runs normal with no load
Old Aug 29, 2017 | 07:43 AM
ultratruck's Avatar
Sounds like it is not getting enough fuel. Have you checked your fuel and air filters? What vehicle do you have?
Old Aug 29, 2017 | 09:39 AM
96 dodge 2500 2wh dr
i just checked the air filter
not anything else so far
Old Aug 30, 2017 | 06:21 AM
ultratruck's Avatar
Also check the supply pump.
Old Sep 5, 2017 | 12:21 PM
ok, my water separator filter was dirty replaced, the pre-heat filter was also dirty, cleaned,
so now its running good. thanks for your help, i need to keep up with my filters.
Old Sep 7, 2017 | 01:31 PM
ultratruck's Avatar
Glad it is going good now.
Old Sep 26, 2017 | 12:26 PM
ok im back, i started the truck Sat am running nice then it went off. no power what so ever. long story short, i worked on it all day n half day on Sunday and gave up so now its in the shop. idles good, no power up hills, really bad now, give it some fuel white smoke from pipe. so i will give an update when i hear from the shop..................
Old Oct 13, 2017 | 05:24 PM
FYI...Transfer Pump was out replaced, back on the road !!
Old Oct 16, 2017 | 06:19 AM
ultratruck's Avatar
Good is was something simple.
Old Oct 16, 2017 | 09:20 AM
i kinda guess that was the problem but that was guessing. thanks for your help.
