6.7 Knock
Old Aug 16, 2017 | 06:54 PM
Ram Guy 08's Avatar
Sad 6.7 Knock
Hi, new to the forum, 1st post.
2008 2500 6.7 Cummins 150k. EGR delete. 5in turbo back exhaust. Cold air intake. Smarty tuner, was on setting 3 (60 hp) when I got it. I've put it back to stock.
Truck developed knocked about a week after I purchased it.
Took it to a local diesel shop and they turned off the injectors one by one. Knock went away when they turned off 6. They told me it was a bad injector.
They put a rebuilt injector in #6. Knock was still there. $500
Then they told me that it's possible I got a bad injector. They said sometimes they're bad right out of the box. So they switched 1 and 6 and did a valve adjustment. The knock stayed in #6. $300
They scoped 6 and did not see any damage. 6 has good compression. Injector balance test showed 6 at 100%.
No blow by. Sent an oil sample to Schaeffer’s. No metal in oil.
Knock seems a little quieter when cold. The knock is very consistent at idle and low rpms. Seems to go away over 1500 rpm.
Anyone have a similar situation? The diesel shop here is not sure what to do next?
Thanks
