REALLY broken glow plug
Old Aug 15, 2017 | 07:57 AM
moocowman's Avatar
Sad REALLY broken glow plug
Threaded part broke off. Insides pulled out. All that's left is the sleeve. I tried to use a broken glow plug extractor kit to remove the sleeve, but the tool broke inside the sleeve! It's basically a tap that screws into to the sleeve to grab it. Then you use the included puller to pull the sleeve out. But as it was pulling (the glow plug didn't budge), the tap broke inside the sleeve. Before this, I already tried penetrating oil, carb cleaner, heating the head and cooling the glow plug, etc. After this, I've started and run the engine hoping compression would pop it loose. Is there any solution other than pulling the head? I saw a video on the ISI engine where he pushed the sleeve into the cylinder and removed it out the injector hole with a magnet. Is this remotely possible with the PSD?
Old Nov 15, 2018 | 07:49 AM
moocowman's Avatar
Just an update a yea later. I ended up pulling the head.
8ntnofoo
Sep 1, 2015 06:52 PM
97t444e
11
Feb 16, 2012 01:05 PM
f550man
Jan 6, 2012 07:46 AM
Chev6.2Dually
Mar 23, 2011 08:46 AM
CHenry
94-98 7.3L Powerstroke Tech Articles
Oct 12, 2008 12:20 AM
