Turbo pressures?
Old Jul 31, 2017 | 07:57 PM
petew's Avatar
Default Turbo pressures?
What should I be seeing for turbo pressures?
97 Chev 1/2 ton crew cab longbox, 6.5 with a heavy camper in the box, {max load weight}.
At full throttle on a hill at 100KPH/60 MPH
cruising at 100KPH /60MPH
Acelerating from a stop normal driving to 60 MPH /100KPH ?
Thanks
Pete
Old Aug 20, 2017 | 07:24 AM
baneric's Avatar
5-7 lbs only.
Old Sep 1, 2017 | 02:21 PM
petew's Avatar
Thanks . I am now in the right range. When I asked the pressures were all over the place, and usualy near zero. After checking vacuum and a lot of other things chasing the problem with poor performance and EGR / Fuel codes I ended up changing the EGR solenoid . After about 50 miles with codes still poping up it suddenly started to pull better, no mode black smoke issues etc. and good turbo readings . It seems like it needed a few EGR cycles to get back to normal.
Old Sep 1, 2017 | 02:37 PM
baneric's Avatar
Default Boost
Your welcome
