Proper VP44 Pump Wire Tapping
Old Jul 10, 2017 | 02:44 PM
Cummims0523's Avatar
Default Proper VP44 Pump Wire Tapping
WANT Tap vp44 but dont know how go about it rather not do it unless get idea how do it
Old Jul 11, 2017 | 04:24 AM
gh0stman's Avatar
IIRC you want to tap the wire closest to the block. What tuner are you hooking up?
Old Jul 11, 2017 | 06:47 AM
i have edge ez with 3 levels everyone saying should tap pump idk if going make that much of difference
Old Jul 11, 2017 | 06:50 AM
gh0stman's Avatar
You are not going to be able to tap the pump with a EZ. Its only good for 65 hp. If you had a quad, tst, or edge JWA you would be able to tap the pump. But with these pumps tapping the pump will produce a dramatic increase over the 65 hp range.
Old Jul 11, 2017 | 07:18 AM
the pump tapwork with edge comp box?
Old Jul 11, 2017 | 07:25 AM
gh0stman's Avatar
Yes it will
Old Jul 11, 2017 | 08:17 AM
so wire tap goes into harness for edge
Old Jul 11, 2017 | 12:30 PM
gh0stman's Avatar
No wire tap goes from tuner harness to the VP wire. All it does is command for more fuel to be delivered. Thus more power.
Old Jul 11, 2017 | 02:24 PM
THANKS BUD FOR INFO
