6.0L Performance Discussion of 6.0 Liter Ford Powerstroke Turbo Diesels Related To Performance And Longevity
2006 F-250 6.0 Transmission Advice and Thoughts Needed!!!!
Old Jun 25, 2017 | 11:56 PM
prdebevec's Avatar
Default 2006 F-250 6.0 Transmission Advice and Thoughts Needed!!!!
I currently have a 2006 F-250 6.0 with 187,XXX.
My problem that i am having is that the transmission recently within a couple weeks started acting weird about the same time 3 of my fuel injectors started failing. When i start up the truck and put it into drive it takes about 3-5 seconds to shift. Once it's in drive it runs pretty well but it will start shifting out of normal when i go to accelerate. Also when i go to slow down sometime the transmission shifts hard to a lower gear. I also have a video of the sound that it had started to make since its hard to describe.
Here are attached videos and photos. I want to hopfully fix the problems myself so i can learn more about my truck. I am going to handle the fuel injectors here soon since 2 are failing and ones about to these have been causing the truck to shudder at around 47-53 mph but after that its fine. I really want to find someone here that has experience or knows what could possibly be wrong.
The transmission is stocked and never been altered, i do admit for 3-4 years i have changed the fluids or filters.
The truck is bullet proofed, sct tuner, upgraded turbo from stock, 4" exhaust, head studs and new everything when the engine was rebuilt and bulletproofed.
Hope someone can help me i plan on going to ford tmw to have them figure out the problem and hopefully its just solenoids so i can fix it myself.
I have a link posted also where you can hear the noise it has been making when in R P and when shifting going down the road and it is a automatic.
