Ford Powerstroke 2011-Up 6.7L Discussion of 6.7 Liter Ford Powerstroke Turbo Diesels
P2043 Code & DEF/DPF delete?
Old Jun 25, 2017 | 05:09 PM
PNW_Steve's Avatar
Default P2043 Code & DEF/DPF delete?
Hey Everyone,
I am looking at a truck to take to Mexico. I am concerned about the lack of availability of ULSD in Mexico so have limited my search to older trucks until this morning.
Today I ran across what MAY be a good buy for me on a 2011 Ford. It is showing a P2043 code.
Will using a programmer to delete/disable the DEF & DPF clear the code?
I am thinking that these are not required in Mexico and are the parts that demand ULSD. If I delete them will the computer ignore the failing heater/sensor?
Thanks.
S.
Old Jun 25, 2017 | 06:05 PM
gunman41mag's Avatar
Moderator
https://www.yourmechanic.com/article...y-andrew-quinn
Old Jun 25, 2017 | 07:38 PM
PNW_Steve's Avatar
Thank you for the link. Cool site with good info.
The question remains.... Will the DPF delete address the code?
Old Jun 26, 2017 | 05:45 AM
Moderator
When you do the deletes, you will bypass the egr, dpf, def
Old Jun 26, 2017 | 11:26 AM
PNW_Steve's Avatar
Will it supress the P2043 code when it does?
Old Jun 26, 2017 | 04:22 PM
PNW_Steve's Avatar
I found a thread on another board that gives the impression that when you program the delete that you can remove the DEF tank. I am guessing that would indicate that a failing sensor will be ignored.
I am reluctant to purchase the truck based on my best guess that the delete kit will resolve the CEL & p2043. Just want to make sure before I drop a bunch of $$
Old Jun 26, 2017 | 04:31 PM
Moderator
All dpf & def sensor will be ignored, you won't get that cel
Old Jun 26, 2017 | 05:06 PM
PNW_Steve's Avatar
Thank you Gunman.
It seamed like it should but things don't always work the way I think they should......
I found a MiniMax "kit" with all of the exhaust pieces for about $1200.
Old Jun 27, 2017 | 04:42 AM
Moderator
I paid about that much, but i have the H&S XRT PRO
Old Jun 27, 2017 | 03:06 PM
PNW_Steve's Avatar
I am not familiar with that one. The MiniMax appeared to be a popular choice among folks posting.
I would welcome any advice regarding programmer choice. My goals are: DEF/DPF delete, fuel mileage improvement, modest HP gain and gauges.
