Won't start
Old May 25, 2017 | 02:30 PM
Drewboys's Avatar
Default Won't start
Hey I have a 99 f250. Had fuel in the coolant. So I replaced the injector cups and put new o-tings on the injectors. Got everything back together done a oil change and drained the coolant. Put in new oil and coolant flush. Went to go start it and now my truck won't start. Need help!!
Old May 25, 2017 | 06:12 PM
joebob3093's Avatar
Moderator
How long have you cranked on it after putting it back together? Is it just cranking and not starting or what is doing?
Old May 25, 2017 | 08:12 PM
Drewboys's Avatar
Feels like I have been cranking it forever. It will turn over but will not start. Trying to stay away from starting fluid as much as possible.
Old May 25, 2017 | 08:13 PM
Drewboys's Avatar
I did spray a little starting fluid to try to get it started it would fire off but die quickly
Old May 26, 2017 | 01:00 PM
joebob3093's Avatar
Moderator
It can take alot of cranking to get it to start, more than you think it should. Do not use starting fluid ever unless you want to lift a head
