Cummins help
Old May 21, 2017 | 12:15 PM
Mitchelldowdell8's Avatar
Default Cummins help
Ok so I have a 2001 dodge 2500 5.9 24v Cummins turbo diesel. It has edge comp 5x5 tuner, 150hp injectors, blue chip vp44 injection pump, raptor lift pump and bigger turbo. I was having problems with the trucks throttle cutting out like the tps sensor was bad so I replaced the tps sensor and the truck is still cutting out, I don't know what to do. Any tips or answers that could help me out?!
Old May 22, 2017 | 03:08 AM
gh0stman's Avatar
Have you scanned for codes?
Old May 22, 2017 | 05:42 AM
Yes I got 4 codes
P1693-fault in companion module
P0216-Fuel timing error
P0122-Throttle position sensor 1 circuit low
Old May 22, 2017 | 05:59 AM
gh0stman's Avatar
Looks like your VP is on the way out. Do you run 2 stroke oil in your fuel?
Old May 22, 2017 | 01:18 PM
No I just run regular diesel
