Timing cover and injection pump gear
Old Apr 9, 2017 | 06:25 PM
89tractor's Avatar
Default Timing cover and injection pump gear
I just picked up a first gen Cummins, of course the first thing to do is the KDP. As i took the timing cover off and at the very top by the injection pump gear it looks like it has rubbed a little bit. I took a wrench to see if I could tighten the nut on the gear, it moved about a little less than a 1/4 turn. Could the gear be warped or is there another cause?
Old Apr 23, 2017 | 02:24 PM
u2slow's Avatar
Did you check for endplay? The whole shaft could be walking in and out.
Has the injection pump been changed? Could have been the old pump doing it?
