1999 Cummins Fuel Leak
Old Apr 5, 2017 | 10:18 AM
Sro757's Avatar
Default 1999 Cummins Fuel Leak
I have a 1999 Dodge 2500 Cummins, truck was fine and recently I replaced the Intake Plenum Gasket and replaced my VP return line on there. A few days after that I was driving and noticed the smell of Diesel and I pulled into a gas station and she was leaking. The Fuel Leak looks like its coming from below the 5th Injector or so above the connection of the return line. It's about a 1 drop per second leak, It doesn't looks like its coming from the Injectors, It looks like it's coming from the underside of the plenum housing, It also drips on the drive shaft while its driving which then throws fuel all over the place. I will upload pictures of exact location later when I get a break from work but I have no clue what is in the area that could be leaking and wasn't sure if anyone has dealt with anything in that area before.
Old Apr 5, 2017 | 01:42 PM
Sro757's Avatar
Also forgot to add, im running a FASS so i deleted both the stock filter housing and the fuel heater. It was installed months ago with no issues so I dont think its related to that
Old Apr 5, 2017 | 03:31 PM
Sro757's Avatar
Its leaking off the bottom of that rear bolt housing(Looks like some sort of plug). The one behind the electrical plug and dripping onto my return line
Old Apr 5, 2017 | 03:41 PM
Sro757's Avatar
Old Apr 6, 2017 | 03:27 AM
gh0stman's Avatar
Check and make sure you have the injector line tightened down. Did you replace the orings on the crossover tube?
If that's not the case pull the group of lines and see if the line has split.
Old Apr 6, 2017 | 09:31 AM
Sro757's Avatar
I did not, what is the crossover tube?
Old Apr 6, 2017 | 09:46 AM
gh0stman's Avatar
It connects the line form the VP to the injector.
Old Apr 6, 2017 | 02:05 PM
Sro757's Avatar
Okay ill have to give that a look, sounds look it could be a possibility. Assuming ive got to remove valve cover to check that?
Old Apr 6, 2017 | 02:06 PM
gh0stman's Avatar
No its just at the end of the VP lines. You would have had to pull them to get the injectors out.
