cruise control questions
Old Apr 1, 2017 | 06:42 PM
Cummins97's Avatar
Default cruise control questions
Hey guys, been a while since I've been on here. Still see a lot of familiar names while lookin around. Well I bought a 95 so I'll be frequenting again.
I got a truck that was an auto swap. Who ever did it didn't get everything working like it should. I'm out to make it right, starting with cruise. The cable is hooked, the vacuum canister is hooked up with no leaks that I can find, the switches in the steering wheel seem to be sending and dropping power like they should be. It does still have the auto column. So is there a position switch on the column so it knows if it's in drive or not? If so, is it a simple jump the wires and where is the switch located. If not, what could be the issue causing it not to work.
Sorry for the long post. Thanks in advance!
Old Apr 5, 2017 | 07:37 PM
Cummins97's Avatar
Figured it out. Thanks for all the input 😎
Old Apr 12, 2017 | 04:39 PM
JBearSVT's Avatar
So what was it?
