Towing Twins
Old Mar 31, 2017 | 07:02 PM
patch's Avatar
Default Towing Twins
Looking for a real quick spool twin turbo set up. I have a hx35 I can use for the lower one but what should I use for the top. I tow heavy a lot 20k most of the time sometimes more. I have a single 63/68 right now it's ok but gets hot pretty quick. I'm running 20* timing have 5x.013 sac injectors 4" exhaust BHAF. Truck has plenty of power it just gets hot too fast. I have to keep backing off when going up hills and I don't want to have to do that. All I'm looking for is 500-550 hp at the rear wheels. I heard a lot of people running the ht3b. I'm kind of leaning toward that but want to know what y'all think.
Old Mar 31, 2017 | 08:09 PM
turbo2332's Avatar
Towing with 550hp gets hot. Your cooling system while moving 20k at 550hp will absolutly need worked over if you do that often. For a turbo if you want to use the hx. Look at a small s400. Something like a 72/83 with a .90 or 1.0 t4 foot. You need to pull your timing back aswell. Be in the 16-18* range. Towing heavy with lots of timing is not a good recipie at all.
Old Apr 1, 2017 | 10:02 AM
patch's Avatar
I don't necessarily need 550hp I know theres a sweet spot somewhere for towing. problem I had wad egts got to hot and cracked the head but I was only running a single turbo and it didn't want to light till about 1600-1750. I can back the timing off to. That won't be that much of an issue. I heard some people using an s369 but not sure how that would work. I just know I don't want anything too big for the bottom one
Old Apr 2, 2017 | 02:08 PM
turbo2332's Avatar
A 69mm wheel would be a joke for a secondary. 57-62mm compressor up top.
Old Apr 2, 2017 | 10:43 PM
patch's Avatar
What you mean it would be a joke? 69mm to small or what?
