2000 24v turbo/injector suggestions
Old Mar 29, 2017 | 08:25 PM
24vburban's Avatar
Default 2000 24v turbo/injector suggestions
Looking to turn up the power a bit. Just got the quadzilla adrenaline haven't installed it yet but it should as some power.
2000 24v
Edge ez (current)
New vp44 blue chip diesel
New lift pump 155gph white performance
Diesel auto power 35% injectors
HX 35
All hooked up to a NV5600 with a single disk Valiar.
Considering a bigger turbo and bigger injectors, dual disc clutch and an exhaust to go with the quadzilla. Let me know what you guys think? What set ups have worked for you?
Truck doesn't pull a ton of weight. Lots of high way driving on economy setting but I like to have the power when I want it.
Thanks
Old Mar 30, 2017 | 05:41 AM
gh0stman's Avatar
How much power are you looking for. There are many different ways to approach. For about 500 hp you can use 7x0.010 injectors, a 62 or 63/68/14 turbo. Clutch I would go with either valair or southbend dual disc. For best mileage I would run the quad turned all the way up and be easy on the pedal.
Old Mar 31, 2017 | 08:12 PM
turbo2332's Avatar
If you dont tow much and your truck is more of a toy go to a 74mm turbine in an s300 frame. Way more punch when she gets going.
Old Apr 3, 2017 | 03:54 AM
gh0stman's Avatar
That's going to be a very laggy turbo.
Old Apr 10, 2017 | 02:40 PM
turbo2332's Avatar
na they arnt that bad when the truck is a toy. laggy when you use the truck as a truck not and empty commuter.
Old Jun 1, 2017 | 12:42 AM
AmericanHotRodSolutions's Avatar
How did this turn out??? Looking to upgrade my 01 very soon. The Fass TD07150G is being ordered Thursday 06/01/17 then after that I will get 5" exhaust with muffler then the Quad Adrenaline.
Old Apr 8, 2018 | 08:21 AM
THICKCOAL's Avatar
WHEN THAT TURBO LIGHTS WITH THE NV5600 YOU"LL EITHER BE GETTING READY TO SHIFT OR BE LOOKING AT THE DITCH IM IN THE SAME BOAT RIGHT NOW I HAVE A 66MM ON MINE WITH 150'S AND A EDGE COMP BOY DOES SHE GET HOT LIKE THE STACK MELTED THE REAR CAB LIGHT KINDA HOT NOT MY DOING OWNER BEFORE ME HAD A BAD IDEA AND IT LEAD TO A REBUILD
Old Apr 8, 2018 | 11:20 PM
NotSoNicely's Avatar
2000 24v
Edge ez (current)
HX 35
Thanks
if you have a BRAND NEW VP44 still under warranty, DON'T tap the pump wire. It'll void your warranty. I would highly recommend playing with the tuning WITHOUT tapping first. That will give you a good bump in power! Im not a expert in the tuning department, however im sure there are many here who can help you. Just some friendly advise.
Old Apr 8, 2018 | 11:39 PM
THICKCOAL's Avatar
Default Good looking out
I appreciate all advise as i seem to be in a void with this the build its self will run me between 8-12k depending on how far i take it like dragon flow and little extra goodies its a rebuilt one not sure of the warranty. Havent heard much of the tapping the vp44 before have to dig into that but as far as i know it hasnt been done
Old Apr 8, 2018 | 11:47 PM
YOU'RE crazy, do what you want. But in total parts cost for me DD and towable work horse(4.5k). All i need is a 62/65/14, quadzilla, south bend, 150's, DTT, and gauges. Already have : ARP, 5", bhaf, ddrp, new tranny and clutch, whatever else im forgetting
