Tire size
Old Mar 23, 2017 | 11:11 PM
Garrett Foote's Avatar
Default Tire size
Hey folks,
I have a stock 94 12 valve and I am looking at moving up in the world and getting bigger tires for the summer. So I have a few questions on what would fit under the truck without rubbing. I have stock 16 inch rims. I'd like to get something beefier because I live in Alaska and half the year I'm switched to smaller studded tires. So I wouldn't mind going bigger the other half of the year. I've looked into 33X10.5 inch tires and was wondering if those would clear? Or what would be the best looking all terrain on the old cummins. -Thanks
Old Mar 24, 2017 | 02:56 PM
turbo2332's Avatar
32/11.5/16's fir on 8inch wheels with zero rubbing and no lift
33/12.5 on anything with up to -24 off set fit with a 2 inch leveling kit
-44 offset and 305/50/20's can fit with no lift with the right tire
33/12.5's with -44 will rub
you can probably shove a 35/12.5 under it with a leveling kit if you go easy on the offset.
