2007 6.0 Diesel No Crank
Old Mar 23, 2017 | 12:16 PM
jason2113's Avatar
Default 2007 6.0 Diesel No Crank
I try to turn on my truck today and it will not crank. The day before I had changed two injectors & once I was done I went to fill up my tank and I put a full bottle of injector cleaner with it. When I drove off, a few blocks down the truck turn off on me. I started to turn on the truck a few times and every time I did it would blow heavy white smoke (Very White) out the tail pipe and then my truck would shut off. I did this about 10 times until I decide to call a tow truck. The next day I empty out the fuel tank and fill it with diesel only. I tried to turn on the truck and it would not crank. I ended putting two new batteries and still the same result. What can this be ?
I heard it might be Hydro Lock with Gas & It may also be the Starter Solenoid that was damaged from cranking so much.
Can anyone help me out ?
