no reverse lights
Old Mar 19, 2017 | 09:09 AM
Andrew Dupree's Avatar
Default no reverse lights
I have a 2006 fummins 6speed. Have no reverse lights. Can someone tell me where the fuse is for them bc mine didn't come with the owners manual and if not then what to do. Thanks
Old Mar 19, 2017 | 01:53 PM
CumminsCoalRoller24/7's Avatar
Check bulbs to make sure they are not both blown. Fuse list below for your reference. There is a neutral safety switch drivers side of trans that it could be also.
owners manual- from cummins forum
Hope this post okay. If not look in your owners manual on page 420
1 20 Amp Yellow Power Outlet Console
2 20 Amp Yellow CCN Door Locks/BTSI
3 20 Amp Yellow Spare
4 20 Amp Yellow Spare
5 20 Amp Yellow Power Sunroof
6 10 Amp Red OCM/VIST Fan/Wastegate
7 15 Amp Blue Reverse Lockout Solenoid Battery(SRT-10 Only)
8 10 Amp Red Heated Mirrors
9 30 Amp PinkOff Road ModulePower
10 5 Amp Orange Trx-Off Rd Pkg Sen (Gas Engine Only)
11 20 Amp Yellow IOD-CNN/Radio/ Under Hood Lamp/WCM/SDARS/HFM
12 30 Amp Pink Electric Brake
13 25 Amp Natural Power-Battery RWAL/ABS Module Feed
14 15 Amp BluePark Lamps Left
15 20 Amp Yellow Trailer Park Lamps
16 15 Amp Blue Park Lamps Right
17 15 Amp Blue Spare
18 40 Amp Green ABS Pump
19 30 Amp Pink Trailer Tow
20 10 Amp RedORC2
21 10 Amp Red ORC Preset Carrier
22 2 Amp Gray IGN Switch Feed
23 10 Amp RedECM/WCM/HVC
24 20 Amp Blue Subwoofer Amplifier (SRT-10Only)
25 10 Amp Red Power Mirror
26 20 Amp Yellow Brake Switch/ CHMSL/Stop Lamp
27 40 Amp Green Power Seats
28 10 Amp RedPower Run/Start-CC/WCM/ABS/RWAL
29 10 Amp Red Switches/EC Mirror/ Smart Bar
30 15 AmpBlue Spare
31 10 Amp Red PCM/Transfer Case Brake
32 10 Amp Red HVAC/Ajustable Pedals/Heated SeatsSwitch LED/ExhaustBrake
33 10 Amp Red Power-IGN Run Misc
34 10 Amp Red Spare
35 15 Amp Blue CNN Illumination
36 25 Amp Natural Audio_Amplifier
37 15 Amp Blue Spare
38 20 Amp Yellow Power Outlet IP
39 10 Amp Red Sunroof/Seatbelt Tensioner
40 20 Amp Yellow Cigar Lighter
41 25 Amp NaturalSpare
42 30 Amp Pink Diesel PCM (DieselOnly)
Old Mar 19, 2017 | 08:08 PM
Mine didnt have the owners manual. I have checked all the fuses and bulbs there all fine. I located the switch on the trans how would I go about testing that? And then what to do after that?
