48re Neutral Safety Switch Leak
Old Mar 14, 2017 | 02:32 PM
CumminsCoalRoller24/7's Avatar
Default 48re Neutral Safety Switch Leak
Neutral safety switch was replaced with rebuild last August. Switch was leaking and replaced in January...switch is seeping again. I am going to do this myself instead of taking it back to shop. If I drain about a quart of atf will that be enough so I won't get a face full of fluid replacing the switch?
Old Mar 16, 2017 | 08:07 PM
Drained entire pan into clean bucket- removed switch without a drop coming out. added gasket maker around oring- waited 30 mins. Refilled fluid. So far so good
