Cold temp
Old Feb 26, 2017 | 02:55 PM
shorthair's Avatar
Default Cold temp
Truck's been sitting for several months & was finally able to get out yesterday outside temp was about 32* & after an hour on the freeway @ 70 mph gauge was still @ the 140* mark & little heat from the HVAC. I'm thinking it is the thermostat since on a good pull it would gain a bit of heat but not much. Any other ideas ?
Old Feb 27, 2017 | 08:05 PM
51Hudson's Avatar
My Dad's 97' was the same way the thermostat is more than likely stuck open, either from rust, or something has broken causing it to say open.
Old Feb 28, 2017 | 06:43 PM
Bigg Redd's Avatar
I would start with replacing the T-stat. While youre at it, give it a good coolant flush and replace with some quality stuff. If that doesn't help, block off part of the radiator with cardboard or the like. That should build up a bit of heat.
