7.3 Help no start!!!!!!!
Old Feb 14, 2017 | 09:03 AM
cowboybobo's Avatar
Default 7.3 Help no start!!!!!!!
Hi im having trouble with a 7.3 2002 manual tranny. The truck quit while idling and would not restart first guess was the cam sensor changed the sensor to no avail icp was puking oil replaced it no difference at this point we started to doubt the cam sensor being good since it was aftermarket so replaced again, no luck. I took to it with a scan tool no rpm while cranking using the scanner so checked the connector harness there is the 5v reference and on the other wire, green wire there is 12v this is with the connector loose and not plugged in just with the key on, there is continuity between the pcm plug and the cps plug with .5 ohm any help is greatly appreciated
