Just bought my first diesel/first gen
Old Jan 29, 2017 | 01:10 PM
SoupCanDan's Avatar
Default Just bought my first diesel/first gen
New to the forum,
I just picked up today a 1993 w250
It need a bit of work but first thing on my mind is that the coolant is low and the exhaust smokes white. I'm assuming head gasket. No big deal, I was planning on doing head studs anyways but.. while I'm there what should I upgrade? I will not be pulling with the truck (more like a Sunday driver) but it has no get up and go. I know Cummins are on the slower side but this truck is almost stock except for a 4" exhaust.
So I would like to do
-Head studs
-A healthier sounding turbo (don't need performance but better fuel mileage or sound is good
-Intake plenum (ram-air?)
-Should I do a header on it?
And what else should be done while I'm there?
I would like also suggestions on parts and brands.
Again not going for extreme amounts of power, and will not be removing the engine.
Old Jan 30, 2017 | 09:17 PM
MasterG73's Avatar
well you could go up to a hx35 turbo which is a noticeable gain in power along with turning up the injection pump, get a denny stage 1 fuel pin, no need for the intake plenum your not gonna make enough power to make it cost effective. do 60# valve spring when you do the head studs, an exhaust manifold is a good upgrade also, diesel auto power makes them fairly cheap compared to other brands. if you go bigger than a 60mm turbo you should go up a size in injectors
Old Feb 1, 2017 | 04:51 AM
blackduck's Avatar
Hungry Diesel fuel pin, get your injectors tested while you have the head off. If they are good no real need to upgrade unless you are after a lot of power.
Better turbo by all means and check the aftercooler for cleanliness and leaks.
But personally I would just get it back together and running correctly then turn the pump up and see how you like it.
The rest are all bolt in as needed.
Old Feb 9, 2017 | 08:31 PM
u2slow's Avatar
I run the BD pin & gov spring with HX35. Spools nice and fast. I haven't had to do a head gasket yet. When the time comes, I'll probably do the high-grade fastenal bolts instead... much cheaper.
