Dodge Diesel Tech Articles All Years of Cummins Tech Talk
Advice On What To Do
Old Jun 4, 2008 | 08:24 PM
biged681985's Avatar
Default Advice On What To Do
i have a 99 cummins. it aint been running in a year. it finaly got it taken to the local dodge dealer. they said that it had to much blowbye. and it would take a minimum of 17 hours to fix. im not going to have them do anything to it. i know it has a cracked block (code 53 block)
which do yall think would be better
A) putting a cheap set of rings in it and tradeing it off for a new dodge.
b) taking out a loan, getting a better block, and moddifing it with new turbo, fuel pump, electronics, and the rest of the works to go along with it.
Old Jun 4, 2008 | 09:24 PM
Uncle Bubba's Avatar
About $5G buys a whole new drop in long block complete with turbo. If it already has a cracked block and the piston and or rings are bad it sure don't sound like it's worth fixin the motor. advertise it for sale with the dead motor and le one a these guys that wants to transplant a 12V have it.
Old Jun 4, 2008 | 09:26 PM
wildbill's Avatar
If the rest of truck is in good shape, I'd go w/ another engine. Still cheaper than dealing with a truck payment and emissions crap.
Old Jun 4, 2008 | 09:33 PM
its an automatic which is in good shape.
has a couple rust spots (truck was from new jersey)
but other than that it is in good shape.
and i already pay 450 a month payment on it now
Old Jun 4, 2008 | 09:48 PM
Nitelord's Avatar
If you haven't run it for a year, it sounds like you don't need the transportation.
I vote B. If you have the money for the payment now. B is for BOMBs baby.....
Seriously, figure out your bottom line on both options. Go with the one that makes the most sense as far as what you need out of the truck.
New or Bombed? Both are gonna cost you $...
Good Luck....
Old Jun 7, 2008 | 12:00 AM
Mountaineer's Avatar
Bomb it.
Old Jun 7, 2008 | 12:34 AM
talked to the bank today and they would only give me 4000 dollars. no wheres enough to even get me started off on just the basics. it sucks havin a truck that dont run. and not enough means to fixer up. so im stuck for awhile till i can come up with enough to get a new engine or figure somethin else out
Old Jun 7, 2008 | 08:39 AM
mikmaze's Avatar
who did ya get it from in NJ, I could go with a few friends and give them a nice hello........... 450 a month on a truck with a bad motor that hurts, time to start looking for a wrecked truck with a good motor, and swap it in there. serious on the visit, I am in NJ.
Old Jun 7, 2008 | 10:51 AM
Whit's Avatar
Site Mascot
transplant a 12 valver in there.....cheap and easy
do yer own blowby test on the one in there
By Bill Flemming
A better way to check engine condition is by a blowby test. This is what Cummins uses and is very simple.
You need a blowby tool. a blowby orifice tool is simply a tee with one .221" (15/64-in) outlet. Connect one end of the tee to the end of the blowby tube. Put a manometer on last tee outlet. That is your blowby tool. They sell them at the Cummins, but I have made my own plenty of times. A simple manometer can be made by looping into a U 6' of clear tubing with water in it half way. Measure how high the water level rises with a tape measure, multiply it by 2, convert it to LPMs
Rough conversion is 1"= 27 lpm, add 3 lpm for each one inch (1/2'' of rise in the tube) of water
New engines numbers are;
63 liters per minute(2.5" water rise = 5" of water) @ 2200rpm,
76 L/Min (3.5" rise) @ 2500rpm
85 L/Min (4.5" rise) @ 2800rpm.
Worn engine that needs rebuilding are roughly double i.e.
126 L/Min(10.5"rise) @ 2200rpm
152 L/Min(14.5"rise) @ 2500rpm
170 L/Min(17"rise) @ 2800 rpm
The valves could also be out of adjustment.
Another way, same idea, is to block the blowby tube with a 1/2'' pipe nipple with a cap that has a 15/64 hole drilled in it. Use 3/8'' id looped clear tubing with water in it slipped over the oil dipstick tube. Use sharp tipped felt marker to mark the water level with the engine off, have someone start an already warmed up engine and run the rpms up to 2.2, 2.5 & 2.8k rpms. Mark each water level with the pen, measure then multiply each by 2.
This is all very simple to do, just hard to explain with words.
Old Jun 7, 2008 | 12:00 PM
Mr.Krabs's Avatar
Found a complete engine at Spalding Auto Parts, used auto parts, used truck parts, salvage, wrecking
thats one thats close to me here in Idaho,but I'm sure theres something closer.
They want 4k for it...was 3k just a few months ago,must be the higher fuel prices? LOL
