2005 6.0 Excursion Turbo Bark and no codes
Hello new to Diesel Bombers
I've got a 2005 Ford excursion that I have we recently installed ARP head studs, o'ring Ported & polished heads with factory gaskets. Also installed HPOP, rebuilt oil rails, bulletproof diesel remote oil cooler, driven diesel regulated return, fast 125 fuel system, and a bunch of other stuff.
The truck starts up like a champ .89 to 1.5 seconds hot or cold. And will monitoring the VGT it starts out 85 to 66 % and slowly drops to 15% and stays there. Key on whine off Map is 14, BP is 14, Baro is 30 mm/hg. At idle map: 14.9, BO:17.5, baro: 30.
Will running truck builds boost really fast and lifting gas slow are fast will cause the turbo to fart/stall/bark or what ever.
Using a Snapon Modis.
Thank you for your help
