Fuel problem
Old Jan 3, 2017 | 08:49 AM
Tech6's Avatar
Default Fuel problem
I have a 1992 12 v it has a new lift pump new ip it will start a run for 15 to 30 seconds and die. But if you crack injector line going to number six it will stay running. Not sure if I have a injector problem or what's going on. Not sure if related to same problem but it does not have any throttle to speak of
Old Jan 4, 2017 | 09:06 AM
blackduck's Avatar
Couple of rough guess's, you are getting air into the system and it is bleeding out via # 6 line when you crack it.
When the IP was fitted did you get the indexing of the throttle lever right?
Cheers Steve
Old Jan 5, 2017 | 08:19 AM
Tech6's Avatar
If it was sucking air wouldn't it run with any injector line racked open
Old Jan 5, 2017 | 05:41 PM
blackduck's Avatar
#6 is the top line out on the pump, guess the air is going to the top of the pump and out the #6 line first.
