Which water meth?
Old Nov 29, 2016 | 05:29 PM
tlevan03's Avatar
Default Which water meth?
I've been looking at the Snow kits and trying to figure out which is best for me. I have an 2006. Basically stock other than and airdog and edge box of course exhaust and intake. 111k on the meter. We tow a 30' camper and other than that it's my daily. I want to run water meth to keep egts down and add a little bit more power. I had a super duty and ran one, but I towed quite a bit at the time. What's the thoughts? Spend my money else where? Thanks in advance.
Old Nov 30, 2016 | 12:27 AM
11B/11C's Avatar
those kits can flood in your cylinder and casue a rod to bend. so if you do install one, i would put some sort of a manual shut off valve in it. what are you seeing for EGTs? i would spend the money else where.
Old Nov 30, 2016 | 11:22 AM
11B/11C's Avatar
Forgot to mention that edge runs hot. So get rid of the edge and get EFI live. EFI is the best tuning you can get for a 2006+ truck, provided you use a good reputable tuner. That's where your money should go.
