Idle seems low
Old Nov 20, 2016 | 09:16 PM
Jlaing's Avatar
Default Idle seems low
Hello every one I am new here I have 94 chev c1500 6.5 non turbo truck starts and runs good but idle seems awfully low (just above second tick on rpm gauge) cel light comes on some times but if I tap foot feed or flip high idle switch it goes away I did the lift pump test and wasn't getting fuel at filter so I replaced the lift pump and filter, truck started right up but still doesn't have fuel at filter If I jump the fuse I have fuel at filter and t handle but my idle still doesn't go up to where I think it should be should I replace ops ? Sorry for long post
Old Nov 20, 2016 | 09:21 PM
Jlaing's Avatar
Third tick on rpm gauge if you count the very bottom one
Old Nov 21, 2016 | 11:53 PM
Jlaing's Avatar
Any one have any ideas?
Old Nov 22, 2016 | 07:38 AM
brdprey's Avatar
as little as i know about diesels. there has to be an idle adjustment some where. shouldn't there be?
Old Nov 24, 2016 | 12:52 PM
Mayhem's Avatar
Electronic injection no adjustments to be made, you sure you have the right pulley on the alternator? A larger one would make it seem the rpm's low the alternator provides the signal to the tachometer.
What codes are you getting?
Old Nov 24, 2016 | 12:54 PM
Mayhem's Avatar
And AC/DELCO only for replacement parts.
Old Nov 27, 2016 | 07:45 PM
Jlaing's Avatar
Hey guys, I replaced my coolant temperature sensor and my oil pressure sensor now the truck is running perfect
